08 cbr600rr wire grounding location
Hi, I've been having trouble with my instrument cluster and I've been told it could be a grounding/earthing issue. I've looked online and can't seem to find where it would be ground to on the bike. If someone could direct me in the right direction, it would be greatly appreciated.
Thanks
Thanks
If it is anything like the F4i (which it should be) then the earth is provided via the 9p connector and not with a direct wire to earth. You would need to check the earth wire. presumably green in colour. All the earths are connected together and earthed to the frame.
