07-08 front brake rotors
RE: 07-08 front brake rotors
ORIGINAL: Jason748
But RSP919's actaully wrong about the 1000RR rotors...
The 04/05 1000rr rotorsare a direct bolt on. The 06+ however uses 320mm rotors, so they will bolt on to a 05+ 600RR wheelBUT to actaully use themyou will need a 5mm caliper spacer for the stock calipers to work without hitting.
When you race a 03, then a 05, and soon a 07 and have an accumulation of race spares... you learn what interchanges real quick.
Actually I was wrong - I looked at my notes when I got home- The 07/08 rotors DO weigh less than the 03-05 rotors, 2.1oz each to be exact - The center is a different design...
That's what I said...
- you never mentioned spacers in your first post...
BTW - why the M4's, why not the P2's or the real deal 30/32's or 32/36's?
ORIGINAL: Jason748
jfunkRR, Whoever told you the newer ones weigh less is full of it... The rotors all weigh the same +/- an ounce or two.
ORIGINAL: rsp919
With spacers they do work, guess I wasn't wrong.
ORIGINAL: Jason748
