05 600rr aftermarket signals! how do i take them off!
thanks........but do you no what bolts and stuff? i don't want to mess this up or take off stuff i do not have to......side fairings too......headlight....etc?
thanks
thanks
im not gonna lie, dealing with the front fairing is a HUGE pain, but to get it off you need to take off the 2 mirror mounts, and the 3 bolts down each side of the bike where it connects to the mid fairing. taking off the ram air duct covers is necessary as well. then once the fairing is off to get to the signals you need to take out the ram air ducts to get to the bolt. oh also after you unscrew the fairing, to detach it youll need to unplug the wire harness that connects to your gauge and 2 wire harness on the left side.
wow......this is going to suck......it seems like the rr is really wierd in the way they constructed it. it isn't very consumer friendy.....thank you for your help.
well i got my signals on but now i cannot line up anything! I have everything on but the right side fairing....the top bolt is crocked and i do not no what is causing this! errrrrrr all i want to do is ride....but my bike is in peices, please help.
ORIGINAL: chuckle1316
Its really not to much. Take the fairings and ram air ducts out. The fairing covering the ram air duct kind of pops out(be careful) You shouldn't have to disconnect any plug wires or anything. Once the ram air ducts are out you'll see the stud for the turn signal. There is a QD on the turn signal wires, undo that and remove the nut from the stud and pull turn signal out. It might take you about an hour to get both of them out. It's not that bad, just remember to put everything back in the way they came out.
