Want more torque.. need advice
Old Jul 13, 2005 | 06:24 PM
ekathryn86's Avatar
Default Want more torque.. need advice
Hi guys,
New to the site. Wonderful one I might add. Thought I'd drop a line with you gentlemen.. and few ladies out there.
Got a question for y'all. I would love to add more torque to my 2000 CBR600F4. How may I do that, what would be best?
I don't really care about losing a bit of top end.. I don't use it all so it won't break my heart.
Given that.. how much is it gonna break me and is it even worth it?
-Kathryn
Old Jul 13, 2005 | 06:52 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: Want more torque.. need advice
It'll be a lot easier, and cheaper, to just rearrange the torque you already have. Drop a tooth on the front sprocket and see how ya like it. If it still doesn't have enough giddyup go up 1 or 2 teeth on the rear. They make 520 conversion kits where you get the sprockets and chain for around $100 or so. It's best to change the chain when replacing sprockets for longest wear. The 520 chain will also help get ya moving faster because it's lighter than stock. Here's one on e-bay.
Old Jul 14, 2005 | 04:18 AM
ekathryn86's Avatar
Screw it.. I'll just slap on a Supercharger and call it even.
Dreamings........
Old Jul 14, 2005 | 09:39 AM
Hey, sprockets are EZ and cheap -- there are turbos, superchargers and of course the 'juice' to add a few extra ponies if you wanna go that route. But it ain't cheap and if it isn't tuned correctly the failure rate increases astronomically.
Old Jul 14, 2005 | 12:30 PM
Anubis's Avatar
and to add to that how much use do you get from a turbo mid corner unless your a guru at setting it up?
Old Jul 14, 2005 | 02:43 PM
ekathryn86's Avatar
Nah, it'd be nice. But I don't know if I'd use it..... wait a second, yes I would.
But yeah, I think I'm gonna go the sprocket route and drop a tooth in the front.
I just have to figure out a way to fix my speedo.
Old Jul 15, 2005 | 04:32 PM
kclyons's Avatar
ORIGINAL: ekathryn86
Get a speedohealer dude.
Old Jul 16, 2005 | 01:30 PM
ekathryn86's Avatar
Yea, but aren't those about a 100 bucks?
Old Jul 16, 2005 | 03:01 PM
Ya -- I posted some links for it somewhere on here. That's the cheapest you're gonna get the error out of your speedo though. A GPS will cost at least $100 plus they're always a second behind. You can do like 30 miles on an interstate and compare your odometer with the milemarkers and figure the error rate -- then just remember where a couple speeds are. The good news is with the lower gearing your speedo will always read a lot higher than you're actually going.
Old Jul 18, 2005 | 02:41 AM
chuey's Avatar
I went 15/45 gearing with a 520 chain conversion. I'm pretty amazed, the powerband is much better for real world riding. It's a bit buzzier now, forcing you to short shift and use the upper gears for the highway, but overall I was thrilled at the difference.
