urgent ...PLEASE HELP..
Old Jun 27, 2009 | 07:36 PM
hoezy's Avatar
Unhappy urgent ...PLEASE HELP..
well let me start of saying that im a novice rider...i just got my first day of trainin out the way...any how , i purchase an 99 honda cbr 600...i took it out for a spin around the neighborhood...i dont know what i did wrong...i dont know if i ran out of gas or what...but i heard a poping sound on my bike and i just thought i ran out of gas...walked the bike to the nearest gas station and with 5 dollar the tank was nearly full...when i went to started it did not want to start...CAN ANY BODY TELL ME WHAT THE PROBLEM IS? AND WHAT I DID WRONG...i rode the bike on first gear...to afraid to put it on second gear...
Old Jun 28, 2009 | 06:20 AM
98formulaLS1's Avatar
well first, you have to start the bike either in neutral with the kickstand down, or in gear, with the kickstand up and clutch in.
Second, if it was making a popping sound while reving, and maybe that was possibly some backfiring, there are a number of things that could be wrong. Like the timing could be off, maybe the carbs, or at least one of the four carbs are stuck open, causing it to unload a ton of gas into the one cylinder.
Old Jun 29, 2009 | 08:37 PM
hoezy's Avatar
did i do anything to cause this? this was the first time i rode it..i just thouhgt i ran out of gas...i started up again to see if i could make it to the gas station..it started but then something poped and i didnt wanna risk no damage to the bike, so i put it on neutral and walked it about three blocks to the gas station...i only put about 5 dollars of gas and it was pretty full...i know cause i kept checking hopin not to over fill...soon after that i try to stated no luck..my concern was that maybe the reason for this was because i rode it on first gear....what you think?
Old Jun 30, 2009 | 09:50 AM
celMNrider's Avatar
I don't think that riding it in 1st gear would have caused any serious damage because the bikes are made to sustain all the way to the redline. If you weren't doing over 70 mph then i doubt that riding in first gear has anything to do with it.
You're probably gonna need to provide a little more info to get a diagnosis. Was the bike tuned when you bought it? Did you inspect the bike before you got on it, Chain, sprockets, brakes, lights, loose cables, etc? Will the bike start back up?
Old Jun 30, 2009 | 11:57 AM
Kayter515's Avatar
u sure the fuel line wasnt set to the off position, it should be right next to your knee. and its a silver ****, kind of looks like the back side of key sticking out. there are 3 positions off, Reserve tank, and on for ur regular tank. if the bike had been sitting a while previous owner may have set it to off.
richbransby
Jan 22, 2013 02:47 PM
Hudson
Feb 8, 2012 02:03 PM
mshoaf
Nov 29, 2008 05:45 AM
lukasz_T6
Jun 18, 2007 12:54 AM
F4i_nsane
Sep 19, 2005 05:05 AM
