UK spec CBR600F4 - MPH per 1000rpm in 6th?
#31
speedo differences
This one says on the logbook "declared new at first registration by sole import concessionnaire"
Thats what is put on the log book for any UK registered vehicle by the official importer.
Honda UK also declared the bike as a full UK spec bike when i gave them the frame/engine/carb and registration numbers.
I am happy enough that it is a genuine UK bike - just curious about the speedo change.
Odd thing is that all of the old MOT certificates are with the bike and they support the milage showing on the clocks ( at least for the last 9 years )
Not long got my log book and in that section it just say "Declared New at First Registration"
I noted my clocks have MPH on outside and small KMH on inside whereas 500tie has KMH on outside and quite large MPH on inside,so I could clearly see a difference from his to my bike by his pictures he posted.
So what does your speedo look like then?
#33
My speedo has MPH outside and KMH inside
The odometer is the only item FIXED to the circuit board
The problem is that the speedo, tacho and temp gauge are easy to swap between circuit boards so making a KMH speedo board look like an MPH board is easy.
If honda had been nice enough to put a miles or km's indicator in the odometer then it would be easy to tell them apart.
#34
not paying attention again or explaining myself
BUT there is a difference between our clocks as my Kmh on my clocks are smaller and appear to be in green (sorry I am color blind too ) and not in white and so prominent like yours are :
Here's a link to ebay on the speedo clocks like i have :
Honda CBR600F4 CBR 600 F4 1999 2000 Speedometer Speedo Guages | eBay
#35
Wow!
I thought I had an American CBR600 (as that what I had linked to) for awhile and was panicking but I also found some English links with the same speedo as I have :
honda cbr 600 fx/fy clocks speedo tacho instrument panel mph | eBay
honda cbr 600 fx/fy clocks speedo tacho instrument panel | eBay
500tie :
looks like you either have a speedo designed for another country in Europe? or its been modified and why your odometer for their and is reading in km's
Would be interesting to find out either way.
Main thing is you have a great bike with lower mileage than you had thought which really won't lose much value, If anything it will go up if you keep it Mint as it is
500tie :
#36
Looking at it I think my bike must have been intended for somewhere in Europe although I can't think where uses mph. Either way I see what you mean with the kph on mine is different to the others but hey ho I'm over the moon with the bike and it all works bar a light on the speedo which I must change
#37
Fairly easy to do and it would make it look like a UK bike.
#38
cBrentb
03-25-2013 06:53 PM
Syed Fuad
12-17-2011 09:08 AM
