those who have done the 01-03 tail swap..
ORIGINAL: crodz600f4
I've heard that the new tail frame doesn't give you the regulator mount so what people have done was had one welded on. I'm doing the research now because I'm thinking of making that swap.
to use a F4 undertray you would have to trim too much off n I'm still not sure it would fit right as mentioned. the F4 tail is a fatass compared to the 01 - 03 tail. I found a trimed F4i tray, tho trimed a bit to much I may find a replacement later on.
okay. here is what you will need to do a swap on the tail end for an F4.
(changing the F4 tail to an F4i tail... the split seat, 01-03 style..see my pics)
1 subframe '01-03
1 tail light wire harness (they will plug right in)
1 Cowl (plastics)
1 F4i undertray
again. there are some things you will have to mod/adjust. to mount the fuel pump bracket and the rectifier... but it can be done with a little creativity no problem
1 subframe '01-03
1 Cowl (plastics)
1 F4i undertray
Hootie233
08-25-2010 03:08 PM
