spark plugs
RE: spark plugs
I didn't have many problems with mine. i was dreading it because I thought it'd be a 2 hour job. I took my time and could do it again in 30 min or less. I didn't have a special tool but just used a long extension, dropped it down the hole and it came up about flush with the valve cover... put the socket wrench on it then...
RE: spark plugs
Yea, pretty much what everyone else said. You have to take off all the body paneling and also disconnect the radiator from its mounts. Some would say to remove the tank as well, but i changed mine with it on no problem. Total work time from start to complete reassembly for me was almost 4 hours, but it was my very first time taking anything apart on the bike. Once you do it once, you can redo it it in 30-45 mins.
I spent about $20 on the spark plug tool by ordering through my local dealer. It worked great for meand I recommend it as itsthe perfect fit to get down into the heads in that small space.
