She lives!
![Smile](https://cbrforum.com/forum/images/icons/icon7.gif)
![Icon Dance Cpatch](https://cbrforum.com/forum/images/smilies/icon_dance-cpatch.gif)
![Smile](https://cbrforum.com/forum/images/smilies/smile.gif)
So I had my rear brake line leaking like crazy so when I removed it, its a Galfer Braided line by the way, I rotated the master cylinder side banjo hole around 180 to give it a better fitment. i put the master cylinder banjo bolt back in with a washer just above and below the banjo bolt as it is supposed to be took it to snug (no torque) went to do the same to the caliper side and this occurred.
Its always something with this bike
![Frown](https://cbrforum.com/forum/images/smilies/frown.gif)
![](http://i46.tinypic.com/1izdsk.jpg)
I really need some assistance here. So I have the Cali bike which I have done the emissions mod on and there is this little guy
(further back so you can see where on the bike)
![](http://i48.tinypic.com/ofr041.jpg)
What is that? CJardine I could really use your knowledge on this one.
![](http://i48.tinypic.com/2vlv69c.jpg)
It seems like it had a serious vacuum lock on the fuel system and I am not sure what it is, I thought it was part of the emissions system but now I wonder. I took it off and the bike ran like a champ, with it on there the bike will run but only with it fully choked and no throttle.
you def want that plugged in. It is your crankcase breather tube and it should vent back into your airbox. make sure everything is clean in your airbox. check your vacuum lines and make sure that they are all hooked up or plugged up; there are 5 total two for the first and one for the rest.
The crankcase breather goes straight from your engine so you don't want it exposed to dirty air.
Yeah def no worries about the banjo bolt Glafer called me the next morn and basically said that they hadn't ever seen one do that, he was especially annoyed because unknown to me but Galfer considers their braided lines 'race' lines so he was pretty annoyed with what happened. He was going to pay the local Honda shop for a OEM Banjo bolt + send me the replacement bolt from Galfer but the shop wouldn't let me pay for the one they gave me so yeah. All is well in my F4 world once again.
