RPMs at Idle, Fuel Indicator, Etc.
#21
you should be able to use kick stand with wheel to the right. just put the bike in gear so it dont try to roll anywhere, turn wheel all the way to the right, and then lean it onto the stand. if it leans too much, put something solid under it, like a piece of 2x6. it will be a very tight fit, but the bulb will come out. tricky part is getting the new bulb clipped into place, and putting rubber cover back over it. first time is always the hardest, but then you learn little tricks for next time.
bucki4lyfe
06-20-2013 03:39 AM
