RPMs at Idle, Fuel Indicator, Etc.
Got the RPMs at idle running at a solid 1400 now and it even sounds better and it's easier to take off as well it seems.
Tomorrow I need to take a look at getting some rear blinkers as it doesn't have any currently, only front. It looks like all the wiring is still good to go for the rear... I may just have to buy the blinker system itself.
rear signals are easy to do. you say there arent any on it... which is weird if it was used as a street bike.. check to see if that bike has integrated tail lights with built in turn signal?? if you get factory signals, they will plug right in as long as the wiring hasnt been chopped.. and if you get aftermarket ones, make sure to get some decent ones, or go with an integrated tail light. good aftermarket brands should have all the proper plugs to just mount it and plug it into the stock harness.
Like Jurgs said, signal wiring is pretty easy to do. LED signals are fairly inexpensive & easy to install. Even if your orig wiring plugs have been cut off, no worries. Just use std wiring connectors (water proof if you can) & install new signal wiring. Your flash/blinking rate will be quicker w/ LED signals but its nothing to worry about. I like mine that way. ;-) I think it draws the attention quicker.
I've got the signals working now! Next step it's replacing the headlight bulb. Unfortunately I cannot do it the easy way under the cluster because the frame sits right up against the headlight and I have no room to pull out. Does this mean I need to take off the wind shield and front body to pull out the entire light fixture?
Ok thanks gotcbr. I didn't get a chance to today but I did ride the bike for a good 120 accumulative miles and my first ride at night (about 30 miles freeway and 15 city). There was a lightening storm with no rain at all which was awesome. Witnessing that kind of scenery and mother nature doesn't compare to in a car... it was purely awesome.
Is there anyway to do this WITHOUT a second person present to hold the bike with the handle bars to the right? My wife is working all day and I really wanted to knock this bulb replacement out in the morning. I don't think my bike has a rear stand and I don't think you can use the kick stand with wheels turned to the right, can you?
