rear stand bobbins
Old Jun 17, 2007 | 10:24 PM
mynavi's Avatar
Default rear stand bobbins
I plan on buying a rear stand soon. I've noticed that some require bobbins while others don't. But when I looked at my bike, I can't find where they would go. Am I over looking the hole?
Old Jun 17, 2007 | 10:38 PM
therabbit's Avatar
Default RE: rear stand bobbins
The mounting point is typically welded on, here they are on my bike:
Old Jun 17, 2007 | 11:32 PM
mynavi's Avatar
So I have to get that welded on before I get my stand?
Old Jun 18, 2007 | 12:06 AM
therabbit's Avatar
Well if you look at my stand you can see there are two sides to the brass looking part, one side has the spool cups, the other side is a bracket, if you don't have the spools you can use the bracket side to lift the rear end up, it just isn't quite as stable or quick.
Old Jun 18, 2007 | 03:53 AM
cwmc29's Avatar
https://cbrforum.com/m_264989/tm.htm
Follow this link to a thread I posted on. You don't need to weld anything to your bike. I got a set of spools that sit in the hollow axle and you just remove them before you ride. The thread also has the eBay link to purchase them. Enjoy
Pugheaven
May 3, 2014 01:26 PM
NEPAF4i
Mar 18, 2014 05:21 PM
bluebadger
Sep 28, 2011 01:54 AM
bluej511
Jan 11, 2008 11:03 PM
