Rear end Mods/Exhaust
Hey Guys. Just a question...I'm looking to change the stock rear end. I'm looking to get rid of the shovel, maybe integrate the tail light (not a big deal if I don't, I'll just flush mount the blinkers) but here's the kicker. I'm hoping I can go 4-2 Exhaust, and I'm wondering if I'll be able to do that undertail. If not my other option is to do 2 high mounts.
So here's the question.
#1. Is it possible to put 2 pipes under the tail?
#2. What do you think is the best full system out there for our bike? (performance before sound please)
RE: Rear end Mods/Exhaust
You have an F4? I dont think you will be able to find a kit or pipes that will just mount up without some effort. you may need to weld or mod some pipes designed for a newer RR. not impossible, just different. i think the trick will be getting the necessary clearance out of your stock sub-frame and tail end. it is not as aggressive as the RR's and therefore, has less clearance. my 99 has a subframe for made for an '01-03. that mod may help a little.
good luck with it. post pics when you get it going. i'de like to see how it turns out
