Put in a manual CCT
Sounds like your install went very well. Glad it works well for you.
I just checked their eb*y listing(s). They list this CCT as "CRU" brand. It appears to be very similar to the APE, which is a nicely designed part.
Thanks
I have a question though. I set mine last year around... June I believe. The bike will make some (normal) noises when cold but they go away when it warms up. I've done about 15k km since then, should I to a slight adjustment or does it keep it's setting good enough to not have to touch it for now? I ask because I feel I might be looking for noise instead of there being a 'problem'. It certainly doesn't make the sounds it did before getting the manual CCT.
