performance
Im trying to put some performance stuff on my bike but not to extreme so far i got Dyno jet stage 1, -1on the front and +1 in the rearwith the RK XW ring chain , k&n filter, yoshi rs3 pipe, ignition advancer, what else can I do that is a bolt on modification? what u guys think I shoul do next?
An ignition advancer will give you more power at lower RPMs. What that means is that there is less stalling from start-ups (if you are prone to stalling) and more usable power from higher (translates to cruising) RPMs. You'll have harder acceleration from the start and no drop in power at cruising speeds.
It doesn't hurt the motor and in fact, it is one of the easier mods to do. Some will say that you'll lose a little bit of horsepower at the higher RPM's but a little is like 1 or 2 so personally, i think it is worth it.
