Oil window?!?!?!?!?
Old Jun 13, 2006 | 03:41 PM
ddvs's Avatar
Default Oil window?!?!?!?!?
Ok, I can't see any oil in the oil window thing on the right side, you know where the oil is supposed to be viewed, am I supposed to tilt the bike to see it? Its on the kickstand and I'm trying to see it but its not there, no oil is visible. Also my bike has started to make a ticking sound, and I'm worried about the pistons ceasing up. Which would totally destroy any hopes of finishing the season. The ticking sound is audible when the bike is in neutral. Also when I am in motion from 1st to 2nd. It kind of fades away after I get up in the gears, after 35 mph maybe, am I in serious danger of critical failure? Let me know because I'm scared ****less about this right now!@
Old Jun 13, 2006 | 04:42 PM
ride_002000's Avatar
Default RE: Oil window?!?!?!?!?
I have the same tiny ticking sound, but bike runs strong... I know it is common on older Katana's but not sure about cbr's...about the oil yes it has to be standing straight up, so have someone sit on it and you can look.
Old Jun 13, 2006 | 05:58 PM
ddvs's Avatar
Hey did you ever find out what the ticking sound is?
neebelung's Avatar
Some bikes are intended to have their oil read when it's on the sidestand (like Buells), and others (like my Kawi) are to be up right (in which case, you need a second person there, in order to get a good view). Check your owner's manual to find out what's right for your bike.
If you're seeing NO oil when it's on the sidestand, however, even if it's intended to be read upright, it sounds like she's a bit low.
Old Jun 13, 2006 | 06:15 PM
I still dont know what the sound is but it doesnt bother me.... I just now noticed it about 2 weeks ago when I changed my oil and used different oil...I went from mobil 1 10w40 full synthetic to Honda HP4 full synthetic. So Im not sure what it is.
ddvs's Avatar
BUT NEEBULING I DON'T HAVE THE OWNERS MANUAL! WHAT AM I GOING TO DO OMG PANIC!!!
Old Jun 13, 2006 | 07:15 PM
IM TELLING YOU WHAT YOU HAVE TO DO.... STAND IT UP RIGHT AND CHECK THE WINDOW.
Old Jun 14, 2006 | 04:12 PM
ddvs's Avatar
so what am I supposed to do? I can't sit on it and check it at the same time
Old Jun 14, 2006 | 04:28 PM
Like I said before get someone to sit on it while you look.
Old Jun 14, 2006 | 06:52 PM
ddvs's Avatar
so let me get this straight, I sit on the bike while I lean over to check the window?
