oil leak under header
Old Sep 26, 2006 | 04:24 PM
shatley's Avatar
Default oil leak under header
Can anyone tell me what those little holes under the headers are for? are they oil over flows? cause my bike is leaking oil from the one closest to the shifter side.
Old Sep 26, 2006 | 05:47 PM
ddvs's Avatar
Default RE: oil leak under header
maybe a gasket or a seal is damaged and leaking, but idk why you should have oil leaking from there. Might be a bad sign
Old Sep 26, 2006 | 06:39 PM
2000cbrf4's Avatar
Here is your answer. Went through it last week. Here is where I explained. No worries man, your bike is fine. $30.00 fix!
https://cbrforum.com/m_164967/mpage_.../tm.htm#165549
Old Sep 26, 2006 | 08:05 PM
shatley's Avatar
awesome i figured my motor was bout to blow! Thanks for the help!
Old Sep 27, 2006 | 02:35 AM
shatley's Avatar
Do i have to drop the motor for the fix?
Old Sep 27, 2006 | 02:48 PM
ddvs's Avatar
no it had to do with something about replacing the valve cover gasket where the spark plug meets the block if I'm not mistaken. it cost's $31.50
pbn85
Aug 10, 2010 10:30 AM
BROWN938
Oct 20, 2008 11:13 AM
klondike1020
Aug 2, 2008 09:05 AM
jwp6114
May 3, 2006 01:18 AM
