New slip on
Just wonder if anyone knows if the slipons from the 05/07 will fit the 99/00 f4
the angle of the headers is different, so if you buy new headers for the F4i than yes a slip-on from 05/07 would work.
Take note any exhaust system is (should be?) designed for a specific engine AND intake system.
I don't know how different the injection is although looking at the fuel consumption numbers there seems to be a difference. From this, installing a slip on noy designed for your carbs can reduce performances. Not trying to discourage you, but if you are experiementing check that you get some extra power besides the noise. |
Any slip-on will fit if you have a midpipe to suit, just need to go to the effort of getting one made up, which is a pita.
if your worried about performance, take it to a dyno, benchmark it than put on the new exhaust and get a jet kit; than put it back on the dyno. you should see performance gains louder noise and a happier rider.
thanks guys not to cocerned about performance have a lil work done already just looking for differant exhaust and there alot more choice for 05-07 and cheaper i know the mounts are the same and the motors are the same all but mine carb and the 05 is fuel injection
Originally Posted by CJardine
(Post 1113126)
(Post 1113126)
(Post 1113505)
Again
Which means he will be using the F4 stock headers. |
yea but the bend in the midpipe is different on the f4 and the F4i
