It's just the overflow hose. The other end connect to the bottom of your tank. If you look at the filler cap area, you will see a drain hole there, that's the ultimate connection. It doesn't matter where it goes as long as it can allow for fuel to pass through if needed.
Wow, thanks for the speedy reply Hamlin! So if I follow you correctly, any overflow from the tank should be going down that tube, then into that canister?
I was just getting read to correct demon by saying, "no the evap canister is on the right hand side of the bike." Then I read your caption. I'm an idiot. Sorry about that. For whatever reason I automatically thought I was looking at the left side.
He, as usual is correct.
