My recent mods
Nothing you all havent seen already just wanted to share my personal results, first I decided to add the mesh to the openings on the fairings. Relatively easy, I found the mesh used for gutters at home depot $2 for a piece big enough for both sides. Next, I had to cut a rough piece, holding the mesh in place over the opening I proceeded to cut and mold closer and closer. Portions of the foam padding had to be removed to allow space to glue it on. After shapping, molding, and triming the piece to size I decided to use "JB kwik weld", only appliyin it at key points not 100% all around just incase I ever need to remove it. Here are the pics....
materials,
cut n mold,
test,
more testing,
before,
after,
and on it,
2nd mod was triming of the rear fender that holds my license plates, I hated how long it was and specially that yellowish light. So I simply decided to disassemble, cut to desidered size, paint and put it all back together. Now it looks cleaner, instead of that ugly yellowish light for the plates I replaced it with some L.E.D. bolts they work great and light it up a lot with a cool soft light blue color. here are the pics
before,
disassemble,
cut and paint,
reassemble,
after,
3rd was the switch for my L.E.D.s, I had a typical push button under the seat to keep people from messing with it but it quickly got old. So after some short research I found a Keyswitch I could mount any where and that could work my lights in a secure and cool way. here are the pics
old switch,
materials: new switch (ebay less than $5),
drill hole 3/4",
assemble and connect,
finally test,
If you all have any questions I'll be happy to help any one who needs info for their projects, laters and keep on riding!!!!!!!!!!!!
materials,
cut n mold,
test,
more testing,
before,
after,
and on it,
before,
disassemble,
cut and paint,
reassemble,
after,
old switch,
drill hole 3/4",
finally test,
thanks, try a "hand-file" made of metal, i used it to grid down some of the edges, theres more control than an open flame.
UPDATE:
Here is the only other thing I forgot to talk bout, I also added these reflective decals on the wings. work is still in progress for finishing the tank but almost there...here r the pics...
Hey dude, I have the same 3m black reflective stuff and I love what you have done with yours! love it
My bike is all taken apart until I get a part shipped in but I will have to throw up some pix of the appearance mods that I have recently made.
Thanks, I also forgot to talk bout the material, 3M Scotchlite. However I cant take all the credit the initial idea was mine but one of my boys that does decals for a living gave it the final touch and great work.
Thanks Dennis, this is the exact product I used, http://cgi.ebay.com/ebaymotors/3M-Sc...Q5fAccessories
3M Scotchlite BLACK Reflective Tape
