Missing Tube - Help Identify
Old 06-18-2009, 10:54 AM
Mobile's Avatar
Default Missing Tube - Help Identify
I just finished a full maintenance run on my bike, including valves, carbs, plugs, brakes, etc..
On the front of the bike there is a small black plastic unit that the hoses that hook to the front faring go into; it then sends a hose out to the air vent control selenoid valve that is hooked up with a rubber grommet to the front of the bike (under the gas 10mm gas tank bolts).
Best I can tell from the manual the unit is called a sub-air cleaner.
Question: One of the inlets to this "sub-air cleaner" has nothing on it; its missing a hose. Again best I can tell from the manual it's for California type bikes only. If this is the case, shouldn't there be something covering the hole? or is it OK to be left open like that?
Cheers!
forza.armata
02-05-2012 07:30 PM
Valter19
08-21-2011 03:48 AM
leviealding
11-25-2008 03:22 PM
mephy04
06-05-2007 12:42 AM
Quick Reply: Missing Tube - Help Identify
