low fuel light wont work
my low fuel light wont work when the bike is low on fuel. i have read somewhere on here about changing the light but i cant really remember. any suggestions would help.
patrick
99 cbr 600f4
patrick
99 cbr 600f4
When my fuel light only came on about the time that the bike would take 4gal or more to fill up. Or like 180miles on that full tank of gas. Make sure you are actually low on fuel before you rip that gauge cluster apart!
Yeah before you take the gauge out just short the two wires on the low level switch together with the bike on and see if the light comes on. Or just short the wire that is not green to ground.
we drained the tank yesterday and it still wouldnt work so we pulled a few things apart and did some tests
turns out it was the fuel reserve sensor that needs to be replaced it is broken
it is really really simple to fix its just a matter of unscrewing the part and putting the new one in
now i just gotta find one
thanks a lot for your help guys
If you're sure the bulb is good and it flickers than you have a loose connection. Bad ground probably. The right way to check the switch would be with an empty tank, measure the resistance between the two terminals. It should be a direct connection, (very low resistance).
we tested the light and it came on
when we pulled the sensor put we werent getting continuity through it and the sensor had come off from the holder thing
just for kicks we pulled the sensor apart and one of the sodder joints had come undone
patrick
patrick
