kleen air mod
Old Jan 28, 2011 | 04:03 PM
nickels's Avatar
I Can't Sell On CBRF
Default kleen air mod
who's done it and knows what i do with the tubes coming off the carbs....i would think i just block them off
Old Jan 29, 2011 | 04:41 PM
Denfrosnesko's Avatar
Are you talking about removing the pair valve? If so tubes just needs to be blocked. I can take some pictures of my bike, but won't get to it before friday.
Old Jan 29, 2011 | 04:42 PM
nickels's Avatar
might be what there callin it over here....thanks man thats what i thought
Old Jan 30, 2011 | 12:43 PM
nickels's Avatar
wouldnt run with the 1 carb tube blocked off so im just gonna hook both carb tubes to the 2 side holes on the air box
Old Jan 31, 2011 | 02:39 PM
You still need two big hoses on the airbox.. damn I can't remember exact which. If nobody else post before friday I will take a detailed picture of my setup. Works great and the bike puts down 102rwhp only with that, bigger jets and k&n filter.
Old Jan 31, 2011 | 04:22 PM
nickels's Avatar
i got it all squared now bro...thanks for the help. Runs good and sounds mean with the shorty pipe i made for it
might need a new radiator sometime bcuz the one i pulled off the wall has a couple pin holes siliconed and jb welded to hold the silicone....then i used stop leak LOL still got a dry shop floor so its lookin alright so far
Old Jan 31, 2011 | 04:45 PM
platnumbob's Avatar
Do you guys want to explain this mod any why it would be done? Not sure I follow here.
Old Jan 31, 2011 | 05:05 PM
nickels's Avatar
for us stunters its done so that the engine doesnt hydrolock and kill itself when the bike rolls over...from what i hear it frees up some hp too.... the tubes coming off the valve cover need to be T'd into each other
Old Jan 31, 2011 | 06:58 PM
platnumbob's Avatar
Cool, thanks for the pic. I don't stunt my bike but I do like HP. Cant be much of a gain tho, 1 horse maybe? Would be interesting to see if someone has dyno'd before and after.
Old Feb 5, 2011 | 10:05 AM
Yeah, free's up some hp.
Kleen air mod increases low end torque and you don't have to worry about hydrolocking.
Removing the pair valve saves a little weight and you get rid of something that isn't necessary.
If you remove it on your road bike you will probably fail inspection.
