jet kit?
What would be the best jet kit for my setup? I have a d&d slipon and a high flow filter. Right now im looking at a dynojet or a factory pro. What are you guys running and what works the best and makes the most power? thanks
I have a shorty wiley co. n a kn filter with a dyno jet. Bench tuned. It made a noticeable difference. The powerband is fatter. The torque is all over the place and the throttle response meets with the fuel injected bikes. Its worth it. On the power between kits depends on ur tuner and if its dyno or flow bench tuned. Ur looking at minor hp diffs. But well worth the bs to do it.
Well i ordereda dynojet and its spposed to be here wendsday. Will there be a chart that tells how to set up the needles and stuff like on what levels because the only way i have to tune mine is just seat of the pants feel but i also ordered a carb syncronizer so i guess ill just try different things.
