Im new and need some advice
ive got a bit of a problem,,, (you can skip this paragraph if you dont want the history) almost two months back i bought a 1999 cbr f4. the bike had been crashed and written off. The po intending to repair it had bought everything he thought he needed to fix it including a new frame because in alberta you cant reregister salvaged VIN numbers. over the next week or so i stripped it down and put the engine into the good frame. then school started and my progress slowed down alot.
im almost to the point were i turn the key and hope the wirings all hooked up right. but the gas tank wouldnt fit. looking at other pictures i can see that the front tab has been bent from the crash (sandwiched bettween cars)
should i try to bend it back or jump directly to ebay?
not sure if the pictures will work but i'll give it a try
[IMG]local://upfiles/29807/B227AC2A8EAE4483968D3BF15EAF71AC.jpg[/IMG]
[IMG]local://upfiles/29807/3EF1945597344221AA4C222FFFC19D64.jpg[/IMG]
[IMG]local://upfiles/29807/4EC9FB9322AA415DB88DF1E606FC69D1.jpg[/IMG]
[IMG]local://upfiles/29807/6240AC535BE0410B89282B21F7CBCFD8.jpg[/IMG]
Guest
Posts: n/a
RE: Im new and need some advice
Because it is welded to the tank probably bending it back is worth a try .. mate
(unless you have the cash to throw away on a new tank )??
If it was molded into the tank you might crack the tank bending it , making it useless ..
Like bigt said ..a body shop would have the tools to give it a go ...
Guest
Posts: n/a
No probs..
when you try to bend it ... see if you can lock the lowest straight point and use good leverage to bend the crook bit back... I know you may not have room to lock the good part if its bent at the tank ..but I though I would mention it mate ..
good luck ..nothing to loose and a hundred bucks+ to be saved ..
my take: fill the tank with water and drain it so you know there's no fuel vapors in there, just a safety precaution. Get your hands on a oxy/acet. torch and heat the bends so you can work them back, should work...if you can't get your hands on a torch then i suggest you get on craigslist or ebay and cross your fingers.
Guest
Posts: n/a
ORIGINAL: Aweasel
Yer a nice idea if...........????
Gezzus mate ..only use a torch if you have had some experience with them ...and be freakin careful
well im 17 and while i dont have any experiance i do have access to a oxy acetylene torch,,, now that your nervous i'll tell you that it also comes with my dad who has used the water in tank method before.
its really tempting to just bend it and see what happens but i have all winter to get this running so i'll just wait for a good time to do it right
thanks for the help
thanks for the help
Guest
Posts: n/a
ORIGINAL: wheeeimflying
thanks for the help
thanks for the help
I was more concerned for the fact that Intensive Care treatment is bloody expensive !!!
good luck
oxy/acet torches are easy if you get your mixtures right and that's something you can get down pat after adjusting the oxy and acet mixture after a while. practice with it and it'll be one of the best tools in your garage. especially for pesky bolts that are too hard to get out or anything needing a good cutting. If you're really slick it's possible to bend pipe with a rosebud tip, a vice, and some sand.
For your tank simply heat the metal at the bent areas and bend it, best way to not get creases and you'll end up with really easy bending, no marring from vice grip teeth, and the worst it would do is burn up the paint. just don't be a fool with it and you'll stay outta the icu. And I mean like put the torch to your face. Basic tool common sense, just like you wouldn't put a sawzall to your wrist.
