I'm idling at 3100k how do i make this stop?
Old Oct 25, 2007 | 04:14 PM
slideways's Avatar
Default I'm idling at 3100k how do i make this stop?
I dropped my bike about a week ago and everything was fine and it ran normal till today it began to idle at 3k rpm, someone told me to adjust the idle screw but i dont know where that is. Any suggestions or help on where to find the screw or how lse to fix this.
Old Oct 25, 2007 | 04:16 PM
fiddy pimpin's Avatar
Default RE: I'm idling at 3100k how do i make this stop?
Check for vacume leaks somewhere...
That will lean out your mixture and raise your idle...
Old Oct 25, 2007 | 06:10 PM
slideways's Avatar
any tips on how to find the leak, ive taken off all my fairings and i cant see any loose hoses, would it be under my tank
Old Oct 25, 2007 | 06:26 PM
crodz600f4's Avatar
The idle screw is a black "****" on the right side (underneath the frame). Make that adjustment first to see if that corrected the problem.If you dropped it hard on the right side, you might wantto check the throttle making sure it's not sticking or other problems with it.
Old Oct 26, 2007 | 06:14 PM
frankmackie's Avatar
yeah. croz is right. the check 1st to see that your choke isnt all the way open (stuck or otherwise)... follow the cable and checkin where it mounts if nec.... then check to see if your screw isnt too high.
that should do it
Old Oct 29, 2007 | 09:23 AM
tecnica's Avatar
can someone be specific or take a picture where the idle **** might be? I'm new to the bike - thanks.
Second question - This is my first bike. I came from a long history of cars - street and race. My idle seems very low and its incredible easy to choke it off at a dead stop. On my roommates Katana, he can just let out the clutch slow and take off. I'd like to do this as well, because I'm not the greatest at only increasing the revs just a little bit. However, if I let out my clutch slowit just dies. I was thinking a 300-500 increase would help me in my noobie trials. I've done this with some of my cars that had light flywheels and it helped smooth things out alot. Any thoughts on this would be great..
Old Oct 29, 2007 | 03:12 PM
not what i would do but if you want, just keep your idle speed higher and let the clutch out. for california, the rpm at (warm) idle should be 1400 rpm. It will die on you if you just open the clutch without givin it gas though. the **** is on the right side, almoast under the seat near the tank. its a black **** with a cable. just look at that area and you cant miss it. i would recommend against the setting your thinking of... the bike might take off on you by mistake if you have it in gear when you think your in neutral. just a thought.
Old Oct 29, 2007 | 03:16 PM
p.s. let your bike reach normal operating temp before adjusting.
Old Oct 29, 2007 | 03:55 PM
cbr6oo's Avatar
I know on my bike 06 cbr600 f4i the **** is on the left side in the opening of the fairing directly under the tank. Its a black **** with a white bable... No pics seeing as my bike it at home and I'm at work....
1400 rpm IDLE????? Mine runs at 1000RPM at idle???
Old Oct 29, 2007 | 04:11 PM
crodz600f4's Avatar
Mine runs at California spec - 1300 to 1400. I think people who've ran lower didn't get enough charge back to the battery at idle.
