How do i check timing?
RE: How do i check timing?
I hope i don't have a serious problem, but when i changed the plugs i remember all of them having fresh oil on them. I just figured they were fouled so there was oil accumulating in the cylinders cuz the plugs weren't firing good enough. But now I wonder if my rings are so bad that oil is causing the spark plugs to not fire correctly. I read a post where someong had too much oil, but i didn't add oil. Unless it has always had too much, but I don't think so. What other reason would I have oil in the cylinders?
Timing is not going to cause oil to foul the plugs. The only reason to get oil on the plugs is oil ring on the piston leaking a bit. To check the timing you remove the valve cover and check the alignment of the marks on the cam sprockets with a set of pistons at TDC. A shop manual will have detailed instructions. It's not that difficult to check just time consuming. A shop will charge you $400+.
nrecore0223
03-05-2008 05:40 AM
