hid q and a
hid q and a
ok so my f4 has the 4i conversion..i wanted to do hid's this winter because i wont be riding as much so may as well work on it rite? my harness is split for the two f4i lights.. its just has the female ends on two wires that go to the light on each bulb, now, one of my lights is on normal, bright lights both come on..so do i get a kit for an f4 or the 4i ? i think the bulbs are some how diff but idk..so im double checking before i buy. tia.
just to give you an idea, instead of the light connectors on the harness, it is just regular wire ( 16 gauge i believe, maybe bigger) with female adapters on the end, and they plug directly to the bulbs, 2 power 2 ground, im assuming that when the po wired it he wired one bulb to the low beam in the switch, and the second bulb to the high beam..so it would would work correctly..pretty smart but it dose kinda mess me up when im trying to figure out my hid swap lol i think i can just order the f4i kit and un the 2 powers and the two grounds to the wires that are already there because i dont have the actual factory connectors..i do however have a multimeter to detect power and ground so i should be ok just to do it that way, correct me if im wrong, but i should just be able to de pin the hid kit and run my powers and grounds straight to it... i hope..
error
" i think i can just order the f4i kit and DE PIN the 2 powers and the two grounds to the wires that are already there because i dont have the actual factory connectors..i do however have a multimeter to detect power and ground so i should be ok just to do it that way, correct me if im wrong, but i should just be able to de pin the hid kit and run my powers and grounds straight to it... i hope..
Here is a pic of the hid connector:
Here is a great write-up for installing the hid's:
https://home.comcast.net/~nstama/hidinstall.html
