Heated equipment?
I use heated grips and ride till the snow in Canada and these works awesome on my 45 min commute everyday.
Motorcycle ATV Snowmobile Heated Hot Handle Bar Grips | eBay
Before you do, make sure your electrical system is in tip-top shape.
You'll be adding a minimum of 100-150 watts to the load,
be sure the bike can out-put it or you'll find yourself stranded, somewhere.
I'm running Gerbing, a jacket/socks and gloves. I'm adding something like 325 watt load.
I beefed up my stator and replaced the r/r to be sure of carrying the load.
I also added a digital voltmeter to the console, so I could monitor and avoid over-loading the system.
I'd also recommend installing the gear on a relay, so you don't forget to turn it off,
while parked.
That said...It's awesome, works great. I've been in 15 degrees for hours, no discomfort.
Ern
while parked.
Ern
Jeff,
OK I just ordered that item, do you have any pictures of how it looks mounted on the bike?
MadHattr,
I'd love to be able to set something similar up, but I'm not sure if my electrics are that great... maybe I can get a buddy try installing the relay and stuff for next winter. Thanks for the info!
BBP
MadHattr,
BBP
I also have mine fused and on a relay so they won't drain the battery if I leave them on.
I don't have any good pics right now, But I put the Toggle switch in the air duct cover and hide the fuse and relay behind it.
I don't personally have heated grips but have ridden bikes w/ them. They make a huge difference, especially if you're going to be riding any long distance. CycleGear sells heated grip kits that work pretty well. You might want to check 'em out...TRACKSIDE Cruiser Gear - Deluxe Heated Grips - Cycle Gear & TRACKSIDE Street Gear - Grip Heaters - Cycle Gear.
As Ern said, make sure your electrical system is tip-top. A quality battery always helps too.
As for clothing/gear... Layering tends to work best. "Cold gear" wicking type layers work wonders. I use glove liners (under gauntlet type gloves), cold gear shirts/pants, neck gators, & good quality socks w/ my boots. Don't know what type of helmet you have but some let in a lot of air... You can wear an under-armor skull cap & it will help keep your head warmer (ears too).
