h7 hids HELPPPPPPPP
Well, changing the fuse will help keep the light on, the only problem is that the wire size (gauge) is only meant for the headlight you have stock. If you put a bigger bulb in and it pulls more amperage, you run the risk of burning up the wiring and harness. Had a buddy that this happened to on a gsxr 600, it melted the wire sheath and the harness.
If you run a new/bigger wire you'll eliminate that issue, and charging capability shouldn't be off by much with only changing a bulb and fuse.
