GPS mounts CBR F4??
RE: GPS mounts CBR F4??
Ram Mount +1
I have mine mounted on the 2 front gas tank bolts.
I brought the Garmin Nuvi 360 kit which is a plate for the GPS, a 3" arm, and a diamond base plate.
Because the gas tank is in the way a bit I ground 1/4" of an inch off the diamond to make it fit flush. I also widened the holes of the diamond plate so they were spaced as wide apart as the gas tank bolts.
The stock Honda bolts are long enough to secure the tank and the diamond plate.
Then you just mount the 3" arm to the plate - and the GPS holder to the 3" arm - tighten, and you're done. Visually a great spot to mount it, and also out of the weather.
[IMG]local://upfiles/9650/33CD206FF4DF41B991720215AA9A5541.jpg[/IMG]
