Ghost keeps adjusting my idle
![Question](https://cbrforum.com/forum/images/icons/icon5.gif)
Has anyone ever had this problem. I cleaned my carbs a while ago and the bike runs fine. I let it warm up for about 15 mins and adjusted the idle at the time to stock settings. Since then my idle has been okay, but lately when i ride my idle increases to about 2200rpm and i have to adjust it back down at he next light. It will be ok for like 5 mins then it will go back up to around 2200rpm. It almost seems at if the vibration is causing the idle screw to turn up on its own or a ghost is messing with me
. Is there anyway to tighten the idle screw to keep it from moving due to vibration or do you guys think it is another issue all together?
![Icon Teeth](https://cbrforum.com/forum/images/smilies/icon_teeth.gif)
Easiest way to test for a vacuum, take a propane torch, DON'T LIGHT IT, just open the gas up and move the torch head around your carb boots and vacuum lines. When and if the engine revs you know where your vacuum leak is. Good luck.
