Front Wheel Question
Old Sep 23, 2011 | 10:41 AM
99cbrf4600's Avatar
Default Front Wheel Question
OK guys I would like to swap out my front wheel with a 5 or 6 spoke design (Well anything but the stock 3 spoke). Anyway I have been reading around the place and it seems like the F3 front rim will fit the F4 without modification with the exception of the rotor. From what I gather, I need to use a 900rr front rotor or a F3 rotor. I would really like to use my current F4 rotor as it only has 3k miles on it. It seems as is the 900rr front rotor is different between the years also.
Maybe the front VFR wheel and rotor will fit. Not sure but it seems to be similar to the F3 front wheel. Anyway any suggestions? I just want a 5 or 6 spoke wheel without too much modification.
Old Sep 23, 2011 | 01:24 PM
gotcbr's Avatar
I have seen a VFR wheel on an F4. However, I don't know the combination of axle, spacers, or rotors.
I don't believe the VFR wheel is any lighter than the F4 wheel. Why add weight for looks?
Old Sep 23, 2011 | 03:51 PM
morpheus's Avatar
Found these on ebay... 01 02 03 04 05 CBR 600 F4i Candy Chrome Rims Wheels NEW | eBay
Old Sep 24, 2011 | 09:14 AM
99cbrf4600's Avatar
Im not doing the wheel swap for a lighter wheel. I am doing it mostly for looks but the wheels I mentioned dont weigh any more than our stock rims. Now I know the F4i rim does way a few pounds less.
Originally Posted by morpheus
Not sure how that helps me as the F4i rims do not fit an F4 without modification but thanks anyway.
Old Sep 24, 2011 | 03:40 PM
morpheus's Avatar
Cool
My bad. I was looking for F4 and didn't notice those were the wrong ones
Old Sep 24, 2011 | 08:11 PM
gotcbr's Avatar
This thread may put you on the track you're going for. Aweasel installed a VFR front wheel & a 900RR rear wheel... https://cbrforum.com/forum/cbr-600f4...e-pics-111740/ .
Old Sep 24, 2011 | 08:29 PM
gotcbr's Avatar
...but the wheels I mentioned dont weigh any more than our stock rims...
If we're talking 6 spoke VFR wheels, then I'm fairly certain this is an incorrect statement.
While it is true that F4 wheels are heavier than F4i wheels, 3 spoke F4 wheels are lighter than 6 spoke VFR wheels.
But since you're going for looks & not performance/less rotating mass, then the point isn't relevant to you. Just posting for clarification for other readers wanting to know the difference.
Anyway, good luck on your project.
Old Sep 25, 2011 | 06:39 PM
99cbrf4600's Avatar
Thanks for your help, I sent him a PM about the front rim for some clarifacation. I will be sure to weigh the wheels to see the difference once I decide on what I need.
While it is true I am going a bit more for looks than performance, I dont see how there would be a huge difference even if it is 3-5 pounds heavier. Well lets put it this way, this is not a track bike and probably will never be. I would probably get a 600rr if I wanted to throw a bike on a track but I simply do not have the riding skills yet
Old Jul 29, 2012 | 04:20 PM
99cbrf4600's Avatar
Update:
I know its been a while guys but I did actually go through with this. I changed the rear to a 900rr rear but the front was left stock. I did manage to test fit a cbr f3 rim on the front and make it work with spacers but I misplaced them right when I was sending out the rims to get powdercoated. F3 rim is sitting in my garage now collecting dust.
Some of you may not like the color but it grows on you after a while. The bike will not change any more cosmetically from here.
Old Jul 29, 2012 | 09:29 PM
gotcbr's Avatar
Looks good.
