F4i shock
Old Jul 14, 2009 | 05:17 PM
squirrel1's Avatar
Default F4i shock
Is the F4i shock (for any years) rebuildable?
My 1999 F4 shock is not, and I want to change the oil and get a softer spring (for my weight).
Old Jul 14, 2009 | 05:21 PM
Wheelie_Ryan's Avatar
Im pretty sure they are, but I do know the f4i shock will bolt right up to your bike
Old Jul 14, 2009 | 06:21 PM
PlayfulGod's Avatar
The F4i shock is a direct boltin. What do you mean a softer spring for your weight? How much do you weigh?
Old Jul 14, 2009 | 06:34 PM
squirrel1's Avatar
140 without gear. The shock feels better (plusher) with the compression turned all the way soft vs. all the way stiff, so that's another indicator the factory rear spring is too stiff.
I've been told by several tuners that they could rebuild my stock shock, but since it's not servicable it would cost quite a bit. Really I just want to change the oil and seal.
Old Jul 14, 2009 | 06:47 PM
PlayfulGod's Avatar
Set at the softest setting should be good for you then. Your weight is more the idea weight these bikes are designed around. Usually you dont have to respring em unless you weigh over 180 - 200lbs. Is yours leaking? Are you trying to set it up for comfort or performance? Performance you would want it harder rather than softer.
Old Jul 15, 2009 | 09:00 PM
squirrel1's Avatar
Nope, it's not leaking, but the ride will improve after changing the 10 year old oil.
Old Jul 18, 2009 | 06:37 PM
VitaminE's Avatar
Squirrel, I sent you a PM re a CORRECT for the F4 Ohlins I will be posting today on here and WERA.
- VE
Speedemon636
F3 For Sale / Trade
Aug 22, 2010 08:14 PM
cbrguy
Mar 17, 2006 10:39 PM
