f4 running problems...
Old Jun 6, 2007 | 11:34 PM
CRAZY's Avatar
Default f4 running problems...
ok. lately i have been having problems with my bike running right. im a stunter. i roll endos like 100 feet and it boggs down and stalls sometimes. it only started doing that this year. never did it befor. so after an endo, i usually just pop start it when i land it. but it boggs on me. well lately, when i go to clutch up a wheelie weather it be at 50mph or 5mph, it boggs down on me. ill be cruising along at maybe 40 bring the clutch in and rip the throttle. and itll bogg right down. i had the tank off befor and noticed a vacuum line was disconnected so i reconnected it and it kept doing the same thing. i also had the 4 little hoses disconnected while i ran it for a f\ew seconds. any ideasss???
HELP!!! thanks!!!!!!!
Old Jun 7, 2007 | 05:51 PM
CRAZY's Avatar
Default RE: f4 running problems...
just cuz im a stunter doesnt mean im not a rider!!! help a brother out!!!
i also found gas in the airbox??? one of them little filters that are actually inside the airbox (not the main filter) was soaked with gas... the leftone to be exact
Old Jun 7, 2007 | 06:33 PM
therabbit's Avatar
Go through all your vac lines and make sure they're connected to where they're supposed to be connected. Those 4 little hoses need to be plugged, if they're just dangling there your bike will run like hell. Those little foam pads should never get any gas in them, oil and a little dirt maybe, but there shouldn't be any way for gas to get to them, get that checked out.
Old Jun 7, 2007 | 07:18 PM
CRAZY's Avatar
the hoses are plugged in to the airbox. plugged. i find it odd that air actually gets up a vacuum hose and into the air box! any idea what would cause this?
Old Jun 7, 2007 | 11:55 PM
therabbit's Avatar
What do you mean that air gets up the vacuum hose and into the air box?
Old Jun 8, 2007 | 03:22 AM
CRAZY's Avatar
lol im sorry, the gas goes up the vacuum hose and into the air box
Old Jun 8, 2007 | 03:38 AM
therabbit's Avatar
Those big vac hoses that go into the bottom of the airbox (where the little foam filters are) are part of the crank case venting system, so if they're blowing gas up into your airbox, you have a pretty substantial problem.
Old Jun 8, 2007 | 10:43 AM
CRAZY's Avatar
one is connected to the carburators! im not sure where the other is connected too. ill hve to look
Old Jun 8, 2007 | 05:20 PM
CRAZY's Avatar
so i figured it out... i think
one of those internal filters in my airbox was soaked in gas. since those vacuum lines dont suck much air it stopped it from sucking anything down. i think it caused a reverse effect instead of sucking in the air, it sucked in the gas which caused some sort of back draw... anyways, its runnin like a champ now!
m21oliver
Oct 1, 2018 10:52 AM
muppet1022
Jan 29, 2014 07:00 AM
harlowz
Oct 10, 2008 02:59 PM
87Cane600
Mar 29, 2008 02:55 PM
