f4 powered kart
Old May 23, 2007 | 02:32 PM
g_b_b_007's Avatar
Default f4 powered kart
Hi team, I'm new in thsi furum, I'm building a f4 powered kart, everything is done, I'm was plugging the fuel lines, but I don't know where is the return line. If somebody has a couple of awnser, i'll manage to fix it.
Is the oem f4 pump running all the time ?
If not, where is the switch/regulator ?
If there is no return line for the system, where does the fuel goes, does it just drops down from the carbs or goes back to the tank ?
What is the fuel pressure required ?
If anyone had a fuel line shematic or can tell me where to get it, it would be appreciated.
It seems very simple but I want to know how the fuel is routed :
Tank -> filter -> pump -> carbs -> ? (carb out to tank - or no exit, pumps stops with a switch)
By the way, I have the shop manual for the 99-00 F4.
tkx,
Old May 23, 2007 | 03:42 PM
*PHOENIX*'s Avatar
Default RE: f4 powered kart
If you pm me your email address i can send you a .pdf file with a load of stuff on the fuel system for the F4 that might be of use to you
Scotti Savage Stoffer
Dec 25, 2014 06:58 PM
CalKirley
Aug 31, 2014 11:18 AM
KidCr3nshaw
Jun 30, 2007 06:14 AM
DDCavi
May 18, 2007 08:36 PM
Anubis
Dec 23, 2005 12:09 PM
