F4 gauges quit working??
Few days ago i installed a 35w HID after that speedometer, odometer, rpm and temp gauge just quit working, so i put the original light back gauges went back to normal (nightime) the next morning the battery was drained, put the bike on 2nd gear pushed hard and started it worked. so i rode the bike for like 30 minutes to recharge the battery. so the battery is fine.(autozone checked the battery its charging fine and good battery) but i discovered that if i disconnect & reconnect the battery the gauges will normal work. but after i shutdown the bike(after riding it for like 20 minutes) and turn the key back to ON same problem the gauges are dead. Hope somebody got a solution on this issue...
Had the same issue, installed a 55W HID and went for at 130 km ride. All was good, lights were awesome. Then turned on bike for the next ride and bike says I'm going 120km/h when I must have been going 40-60. I stop bike says 80km/h. I'm too far from home to do anything since I was at buddies place. Drive home and notice odometer is blank. I pull over and shut my bike off for a minute, turn back on and speedometer is working, odometer still just a blank lit screen. Get home it's late, try to poke around but can't see anything so I just leave it. In the morning odometer reads 1km and no gauges work...
