F4 with F4I bodywork and cluster?
Old Oct 16, 2011 | 03:18 PM
Squidbilly's Avatar
Default F4 with F4I bodywork and cluster?
Can one put F4i race fairings and instrument cluster on a F4?
Old Oct 16, 2011 | 04:37 PM
CJardine's Avatar
Track junkie & modaholic
Yea you can, there are a lot of post on these subjects, if you do a search you should be able to find them.
as far as the stuff you can do you can just put the F4i gauges or the gauges + the upper fairing, the side fairings are the same from what Ive been able to tell and you can also convert the banana seat over to the split seat of the '01-'03 F4i's. Ive done this and its really easy ad you can do it in an afternoon.
Old Oct 23, 2011 | 09:27 AM
99specz32's Avatar
you'll need the mainstay aswell, which will hold the upperfairing and the gauges, also dont forget a windscreen.
I had the f4i conversion done on my f3, but it was stolen a few weeks ago. Picking up an f4 this week, gonna have to do it all again....
Old Oct 23, 2011 | 11:46 AM
rpmraper's Avatar
the tail fairing will bolt up almost directly, the back two bolts go good but the front two dont, idk what everyone else dose to solve this i didnt want to drill into my frame so i just used black zip ties.. other than that everything else bolts up from my exp.
rpmraper's Avatar
oh also get the correct tail light aswell lol
Old Oct 23, 2011 | 01:03 PM
gotcbr's Avatar
To strictly answer your question...
NO, you can't directly install the F4i race fairings & instrument cluster on the F4.
However, you can put F4i race fairings (front cowl) & instrument cluster on the F4 -IF- you install the F4i front fairing stay. The front cowl & instrument cluster bolt directly to that front fairing stay. Note: you'll need the F4i windscreen as well. Also, air-duct covers are different (if you still want to utilize them).
As for the tail... You can just order the race tail cowl that you want. The race tail cowls typically mimic the split-seat cowl look...i.e.- single rider seat. Most race tail cowls utilize a *seat-pad* not a real seat. That may or may not be suitable for you.
The other option for the tail if you want the actual split-seat setup... Do the split-seat conversion. My split-seat tutorial is in my photo-gallery. To do this, you'd need; 01-03 split-seat subframe, battery-tray, tail light, tail cowl, front & rear seats, necessary hardware (most reused from F4). Once you've done this conversion for street, you can easily swap out the street plastic for race plastic.
Good luck w/ your project.
Old Jan 9, 2012 | 12:20 PM
armyjeffries's Avatar
Is this the mainstay? HONDA CBR600F4I FAIRING STAY BRACKET CBR 600 F4I 01 06 + LOWER CBR 600 F4I 01 06 | eBay
Old Jan 9, 2012 | 12:41 PM
gotcbr's Avatar
It appears to be.
CBR1988
Aug 27, 2011 06:55 PM
wrexalot
Sep 1, 2006 07:10 PM
