Is this dimming normal (video)
Old Nov 14, 2020 | 04:03 PM
tommytwoshoes's Avatar
Default Is this dimming normal (video)
Is this dimming normal? Now that it's dark during my daily commute, I've noticed that the dash and headlight dim in time with the indicators (standard filament bulbs all round).
Nothing was mentioned about it during the bikes recent MOT inspection. The battery voltage is 12.3, 14 and a bit engine running; terminals & leads are all clean and bright, and I can see the rectifier is the later type with heatsink fins.
Last edited by tommytwoshoes; Nov 14, 2020 at 04:21 PM. Reason: hmm can't seem to upload video
Old Nov 24, 2020 | 12:20 AM
Dink.1170's Avatar
Registered Users
Relatively normal, may benefit, from all the earths being cleaned.
Dink.1170
Old Dec 5, 2020 | 01:07 PM
Shauncb's Avatar
I had the same exact issue with my bike, would start and run fine, system charging as normal, but when I would switch to high beam or trigger the brake light all lights would flicker and even the ignition would cut out for a split second, I cleaned the ground on the frame under the seat and to the left rear of the fuel tank, it's an 8mm headed bolt and it fixed all the issues, might wanna check it as it's a simple and free thing to do. Good luck on your issue, hope this helps.
Old Jan 11, 2021 | 12:57 PM
Thanks everyone, so icy here the bike has been parked since before Xmas. Shaun, do you mean this rusty lead bolt going into the main fuse? AFAIK the FX only has one ground point, disappearing down by the gearbox.
Old Jan 11, 2021 | 02:20 PM
74demon's Avatar
That's your starter relay. Those are not grounds, they are very positive.
Old Jan 11, 2021 | 05:09 PM
Thanks 74demon, where should I be looking for this underseat earth point, is it closeby?
Camey
Jun 10, 2013 04:26 PM
600f4ilover
May 4, 2013 08:53 PM
jasonchristopher
Jan 21, 2013 06:18 PM
600f4ilover
Jan 8, 2013 11:10 AM
Conrice
Jul 13, 2012 01:18 PM
