Cylinder 4 (right hand side)running cold
Old May 9, 2023 | 01:11 PM
Connella08's Avatar
Your idle jet will be a screw in style jet. Should look like this one.
https://www.partzilla.com/product/ho...xoC2QoQAvD_BwE
Old May 10, 2023 | 10:01 AM
Cbralf's Avatar
​​​​​​Update:
​​​​​​Have a spark
have compression of around 140 at idle
gone through the jets again definitely not blocked and cleaned whilst out float sitting fine fuel supply working fine all air tight and the cylinder still running cold about 100-150° lower than other 3 and a slight misfire after blipping the throttle. Do you have any ideas where to look next looking at maybe cam chain tensioner diaphragms or needle not pulling up and not getting enough fuel in to the 4th cylinder.
Old May 10, 2023 | 10:30 AM
Connella08's Avatar
Cam chain tensioner wouldn't be the cause of the symptom you describe. 140 psi sounds adequate, but you also want to check it against the other 3 cylinders. They should all be around the same. If you have 1 cylinder measuring significantly lower, then I would say you have a compression problem but I still doubt this is your problem. If you have spark at cylinder 4, this definitely sounds like a fueling issue. You may want to check to make sure the carburetors are synchronized. This can cause running issues, but I would still lean towards a clogged jet/passage somewhere.
Old May 10, 2023 | 12:44 PM
dannoxyz's Avatar
There's more to cleaning carbs than just jets. It's like garden hose and everyone's focused on sprayer at end (jets). But what about the 20 golf-***** stuck in hose along way??? To properly restore carbs to OEM fresh clean condition, needs:
- scrubbing out all secret hidden passages in carb-body with brushes and PEA-based fuel-system cleaner
- poking out all bleed holes with soft copper wire of matching gauge
- ultrasonic soak everything
- micro soda-blast
- replace all rubbers, float-valves, fuel-rail O-rings, pilot-screw O-rings, float-bowl seals
- set and test float-levels
- sync carbs with manometers
Skipping any of these steps will result in bike running unevenly.
Scrub-brushes from amazon:
Amazon Amazon
Ultrasonic cleaner:
Amazon Amazon
Micro soda-blaster: https://vaporhoningtechnologies.com/...-a-carburetor/
Manometers:
Amazon Amazon
Old May 10, 2023 | 04:34 PM
rockpool's Avatar
He should have 4 coils, 4 plugs and no leads as the F4 is a coil-over-plug setup.
well look at that! I was totally mistaken - good catch!
https://www.hondasportpartswarehouse...-harness-99-00
mdurak00
Jun 6, 2012 09:27 PM
89HurricaneF1
Apr 30, 2012 09:53 PM
jmj166
F2 Tech
Mar 24, 2010 07:41 PM
