Clutch Problems
Clutch Problems
Ok before I go into too much detail, can anyone confirm if the centre clutch spindle should move in and out about 10mm because at the moment we have no clutch and all that appears to be happening when I pull the lever is that the cable just takes up the play in the spindle? Clutch has been built up using the correct EBC SRK kit as per manual.
