Cleaning carbs, notoced valves are flithy. What should i do?
RE: Cleaning carbs, notoced valves are flithy. What should i do?
to clean the carbon deposits out of around the valves start your bike with the tank and top of the airbox off of the bike---- get a squirt bottle with water in it and rev your motor to3,000 RPM and get a fine mistof water and spray directly into the butterflyof the carb---- Repeat on all carbs----- its oldschool but it works great--- i do it all the time------ if your lazy you can just buy some seafoam fuel additive and put it in your gas but watch to not get any on your pain because it will take it right off---- later
Please dont shoot water in your engine, it can oxydize your rings and scar the cylinder wall. Water injection is used on boosted engines to cool the intake charge, changing the state of the water from liquid to gas in the manifold not the cylinder. The manual explains exactly how to remove the cylinderhead and disasemble ,inspect, and clean or replace parts.
ORIGINAL: therabbit
The stickied post at the top of this forum has a link to a how-to for cleaning your carbs [8D]
My suggestion for cleaning your valves is to use sea-foam. You mix it in with your gas, and it helps clear anything between your fuel filter and exhaust out.
