Carb cleaning writeup?
RE: Carb cleaning writeup?
ORIGINAL: serge1284
ok thanks bergs ill sync my carbs and whats the best height for the floatsand the right amount of vacuum should the carbs be pulling ?
A service manual helps immensely and even beyond the book, there are a few tricks to getting accurate measurements and accurate adjustments.
Some floats aren't adjustable and if they are out of spec, new floats are recommended.
Based on your questions, I would not tackle this if I were you unless you have an experienced person right there to guide you.
That's not meant to be a dig. In reality, it will cost more time and frustration in the end if you mess up and end up having to trailer the bike to a dealer or experienced person to make it right.
yo bergs sorry for that stupid question i should of researched it before i asked ,i looked it up on the HOW-TO section and it seems like something i wont be able to tackle myself so ill just clean & sync my carbs and leave the floats alone cuz one rider wrote that he bent his and the bike would not even start ,thanks though
No stupid questons that I could see.
If you really want to get them cleaned and set the float height, you can send your carbs to me and I'll have them turned around to you within a day. I see you're in PA....I'm inNH.
The sync is on you as it's my belief the proper way is to use the engine they're attatched to.
PM me if you want and I'll get you more details.
ORIGINAL: platnumbob
quick question.....if one of your floats was "stuck" would it cause the bike to perhaps leak gas when parked? Mine has recently started to leak gas out of the tube connected to the fuel pump (I think its the fuel pump).
To the OP, I wouldn't touch the carbs if the bike is running well. Carbs are the kind of thing that once they are set, they stay. Other than the occasional bottle of gumout there is no reason to touch them.
If you are new to bikes there are things you can do to keep your carbies clean and healthy during the boring winter months.
You'd have to pull the carbs off and take the float bowls off to get to the floats. Check them all that they all move freely, and don't have gas in them. Do not grease the pins, as gas will dissolve the grease and there is stuff in grease that can clog the jets.
