Carb cleaning writeup?
Old 01-15-2008 | 06:00 PM
F4Stunter's Avatar
Default Carb cleaning writeup?
Anybody know of any good carb cleaning how-tos?
Old 01-15-2008 | 06:11 PM
Nauree's Avatar
Default RE: Carb cleaning writeup?
Will it run in the first place or is it so gummed up it won't start?
Old 01-15-2008 | 09:49 PM
F4Stunter's Avatar
Bike starts and runs fine. Just basic maintenence. Trying to keep busy in a cold garage.
Old 01-15-2008 | 10:48 PM
bergs's Avatar
No need to clean if it's all good.
Old 01-15-2008 | 10:59 PM
DonEverett's Avatar
https://cbrforum.com/m_311016/tm.htm
Theres the link. Like the others, I wouldn't suggest it unless you need to.
Old 01-16-2008 | 02:16 AM
F4Stunter's Avatar
It couldnt hurt though could it? They probably havent been cleaned in well over 10k miles. Basic maintenence isnt it?
Old 01-16-2008 | 08:18 AM
Nauree's Avatar
No its not basic maintenence if it starts fine. Gas keeps it clean. You'll probably gum them up by taking them appart and letting it dry out.
Old 01-16-2008 | 12:28 PM
Bumble Bee's Avatar
And if you take the carbs off you will have to sync then again or have them synced. If it runs fine-leave it alone. In the spring just get some good intank carb cleaner and run it threw-that's what i'm going to do.
Old 01-16-2008 | 06:49 PM
serge1284's Avatar
what do you guys mean by synched ,what does this mean ,and will i need it done on my bike if i clean my crabs which i will this winter thanks ,sorry for stupid question first time im going to clean carbs also ,thanks
Old 01-16-2008 | 07:11 PM
bergs's Avatar
ORIGINAL: serge1284
LOL
Yes, clean your crabs first before anything...
Basically carb syncing is balancing the amount of vacuumthe carbs are pulling so they are all equal to one another.
Yes, you will need a carb sync tool or you could search the web for "home made manometer" if you wanna build your own.
Two things I highly recommend if you do clean your carbs is setting the float height and syncing (Iusually refer to it as"balancing")
Quick Reply: Carb cleaning writeup?
