California
You can do a vin check, normally it will say where it was first registered. Has the PO removed the PAIR valves and direct air system, or messed with anything under the airbox? Another way is to check your jets, cali bikes have different ones.
Edit: Also look for the evap canister behind the alteration, below the front sprocket, on the left side of the swingarm.
