Best way to r & r OE handgrips ??
Old 11-26-2007, 03:15 PM
screaminwoody's Avatar
Default Best way to r & r OE handgrips ??
hey everybody...new guy here...i've got a 99 cbr600f4 and i'm replacing the OE gripswithgel grips...what's the best way toremove the OE grips ? And also any tips on putting the new grips on ? i've heard using dish soap helps.i've also heardthat some peopleuse adhesiveonnew grips and some people don't?? any thoughts on that too ? thx !
Old 11-26-2007, 05:42 PM
Default RE: best way to r & r OE handgrips ??
yeah u can cut the hold ones off and adhesive is great for the gel grips incase they slip for any reason
Old 11-27-2007, 11:54 AM
I have never done my grips before, but I put the rubbers on my levers on my old bike with soap/water. It took a little work but i got them on. I would guess it could work the same, I could be wrong though.
Old 11-27-2007, 01:55 PM
toaliosis's Avatar
Luckily for me, mine came right off with a lil twisting and pulling.
Then to make sure they stick, I sprayed the inside of the new ones down with some hair spray.
Old 12-02-2007, 09:14 AM
KRUSHER F3's Avatar
Remove your barends, use some compressed air (if you don't have an air compressor this wont work) blow air between the bar and the grip as you are trying to pull it off. The air will temporarily expand the grip enough to make it slip. You may have to do this more than once to get the grip off. When you re-install the new ones push them as far as you can then blow air up in between grip and bar as before as you are pushing them on. Again it may take more than once to get it all the way on. This has worked for me every time and I've never had to put anything in or on them to get them to stay.
Old 12-03-2007, 08:35 PM
OC's Avatar
OC
OC is offline
The easiest way to remove the old grips is to use a lubricant. Just pryup the edge of the grip and use the straw that comes with the WD-40 can to shoot some in there. Then twist the grip to work the lube around and it will slip off in no time.
Old 12-09-2007, 10:04 AM
i use to bmx and thats what i did
dont use soap because it cam make the grips slide off when your riding
which would not be fun
ORIGINAL: toaliosis
Old 12-09-2007, 01:27 PM
KidCr3nshaw's Avatar
Razor blade the old ones off and use yo mammas hairspray inside the news ones. Let 'em soak for a few minutes and put 'em where you want 'em. Leave them alone for a couple of hours.
CorruptFile
01-20-2013 09:08 PM
Bazza
10-24-2012 08:25 PM
screaminwoody
11-26-2007 07:23 PM
Damion
01-21-2006 01:43 PM
Quick Reply: Best way to r & r OE handgrips ??
