another charging problem
Old Mar 24, 2011 | 01:38 PM
OdessaF4's Avatar
Question another charging problem
I bought a new battery august. Battery will not stay charged, i can go about 100 miles before it dies. i have done all the test on here for checking the stator and the reg. only question i have is when i have the voltmeter on the battery and i rev the bike up to 3grand it doesnt shoot straight up to 13.5v -14v, it slowly builds up to 13.5.
I just moved to west texas and its been nice weather for the past 2 months and i need to get this fixed so i can be out there riding, any help would be great.
Old Mar 24, 2011 | 03:03 PM
gotcbr's Avatar
Welcome to the forum.
If I had to diagnose based only on the statement in your quote that I underlined, I would have immediately suggested you take a look at your R/R. Honda superseded the old F4 version for a newer finned version, that is more reliable & less prone to failure (I've documented this in my older posts on the subject w/ part numbers, etc).
While the stator can be problematic in a situation like this, its less likely. Stators typically don't fail easily...usually some sort of impact or damage to the stator is necessary to generate its failure.
Your battery, while relatively new, how has it been stored since last August? That was 7 mos ago. Has it been on a trickle charger/battery tender? Has the bike been run in that 7 mos? Too, its possible that the battery was defective or weak when new. Perhaps remove it & have a second test done it by the shop to verify your findings & go from there.
Hope you get it figured out.
Old Mar 24, 2011 | 03:28 PM
OdessaF4's Avatar
i been riding here and there the past 7 months, just when it goes died i hook it up to the charger. my old battery i can charge it up, throw it on the bike and hook the voltmeter to the batery and rev the bike up and the volts wont even really move at all. so when i bought this new battery from the shop back in kentucky they guy put it on charge and i picked it up the next day, i wonder if the guy really put it on the charger.
Im going to run the battery up to the shop and have them test it. like i said i did all the test on the reg/rec and the stator and the only thing i questioned was when i reved the bike up it slowly climbed up to 13.5v with the newer battery, with the old battery would even move.
Old Mar 24, 2011 | 06:41 PM
brveagle's Avatar
I would suspect two things...
1) bad battery. What is the voltage of the battery when it dies? what does the battery voltage drop to when you are cranking it?
2) slow short.
Old Mar 25, 2011 | 12:13 PM
OdessaF4's Avatar
i charged the battery over night. the voltage was at 12.6. when i turn the key on it drops to 11.9. when i start cranking it it drops to 10.89.
Old Mar 25, 2011 | 01:38 PM
OdessaF4's Avatar
i just did the current leakage test with the battery charged and i get 0. i undo the reg and i still get 0. is this correct or should i be getting something
Old Mar 25, 2011 | 04:34 PM
gotcbr's Avatar
OdessaF4, I recommend downloading the F4 Service Manual (links here on the forum). Refer to Section 16 - Charging System, starts on Pg 305. All the specs & test procedures are listed.
Current leakage = 0.1
R/R = 0.1 - 1.0
Good luck.
Old Mar 25, 2011 | 04:42 PM
OdessaF4's Avatar
i already have that, thats what im going by. i know my meter is good, i use it everyday for work and i used my coworkers. i should have some kind of leakage
Old Mar 25, 2011 | 06:30 PM
gotcbr's Avatar
To clarify my previous post, for a fully charged battery, 0.1 is maximum. So if you got 0 voltage drop, 0 = good.
I'd redo/verify the tests for the battery, see if the battery will hold a charge, test the R/R, compare results, & go from there.
Old Mar 29, 2011 | 03:40 PM
Blindside's Avatar
It is the R/R. Had the exact same symptoms and replaced it - problem fixed. Bought it on ebay from china for like $20 free shipping.
