Air Injection Control Valve?
RE: Air Injection Control Valve?
Don't know too much about itbut what I do know it has to do with emissions. They say it doesn't require a whole lot of maintanence. But if you have some overheating issues, or backfiring then it may be something to look at. In cars... if it doesn't pass smog, the valve is something to look at. But this is pretty much all I know.
Again I'm not 100% sure but I think both have a part to do with emissions. I thinkPAIR is the secondary air system to yes "flush out to thin out vapors before it goes into the world"... it's part of the emission system. You should inspect the PAIR valveto rule out the possibility of solving you bike's problem. My manual says to do a vacuum test but I would also check the condition of the valves also.
