adjusting jets
Old Sep 13, 2007 | 11:55 PM
loyboy10's Avatar
Default adjusting jets
i am running incredibly rich with my dyno jet kit and needed to know how to adjust them correctly!!
Old Sep 14, 2007 | 07:48 AM
Det99cbrf4's Avatar
Default RE: adjusting jets
Are they even adjustable? I thought a certain jet kit injects X amount of fuel. Could be wrong.
Old Sep 14, 2007 | 09:49 PM
crodz600f4's Avatar
Do you have a pilot screw driver? It's a special angled screw driver that you can getto the carb pilot screw. What you need to do is turn the pilot screw until it seats (closed). Then turn it 2.75 to 3.0 in the opposite direction in Cali, but 3.25 in other states.. Dynojet instructs to turn it 3 turns and do a synch carb. If you don't have the pilot screw driver then the only way to get to the pilot screw is to pull out the carb so you can get to it.
Pull out the carb and it'll be the screw on the right, bottom side. Turn until it seats then turn the screw the number of turns. Put the carb back and the airbox but attach the tiny 4 hoses to the synch. Once the carbs are synched then put the hoses to the right spot. (I suggest you label everything before you take things off and get a manual before you start.)
Good luck
Old Sep 15, 2007 | 09:45 PM
loyboy10's Avatar
thanks a whole lot, that is a lotof help!
Old Sep 15, 2007 | 09:57 PM
loyboy10's Avatar
hey, yea i found this
http://www.dynojet.com/pdf/1196.pdf
Snapp
F2 Tech
Apr 12, 2011 09:57 AM
stensg
Sep 30, 2010 08:34 PM
sloppyjones
Jun 1, 2007 11:19 PM
kevvydude
Jun 14, 2006 07:44 PM
