about to give up
Old Jun 12, 2012 | 07:41 PM
sccbr600's Avatar
Default about to give up
Ok guys need some more help, when the bike is cool it runs excellent like less than 10 miles but after that it starts loading up and flooding going down the road. I've cleaned carbs 3 times new fuel filter new plugs new r/r, any help would be appreciated thank ya'll.
Old Jun 12, 2012 | 08:15 PM
MaikuMizu's Avatar
adjusted floats?
Old Jun 12, 2012 | 08:55 PM
sccbr600's Avatar
Nope I sure didn't thanks man. It's just weird it runs so good till it gets hot.
Old Jun 13, 2012 | 02:33 AM
MaikuMizu's Avatar
I have no idea what I'm talking about. I'm shooting in the dark, but it seems like once the carbs have some time and vacuum in them, they overfill causing issues? Make sure the pin thingy isn't stuck and that they move freely, then check adjustment... I think?
Old Jun 13, 2012 | 07:04 AM
sccbr600's Avatar
I don't have a clue either but its something I haven't done so I guess ill give it a try, thanks again man.
Old Jun 13, 2012 | 10:40 AM
cobra1000rr's Avatar
how well did you clean your carbs? did you put in new float needles. you could even need to sync the carbs. sounds like it runs fine while its in warmup, either electrical or carbs are causing you to run rich and dump fuel.
Old Jun 13, 2012 | 12:28 PM
sccbr600's Avatar
No I didn't put new needles in I used like 3 cans of carb cleaner, blew every thing out with air. It runs rich all the time but its bad when it gets good and hot. Thanks for responding.
Old Jun 13, 2012 | 12:29 PM
sccbr600's Avatar
And I did sync them and they where real close.
Old Jun 13, 2012 | 08:23 PM
sccbr600's Avatar
Well the float adjustment seems ok, now what?
Old Jun 14, 2012 | 01:00 AM
cBrentb's Avatar
check the fuel pump, its a good place to start. make sure its the correct pump for the bike and pumping right pressure. have you riden it latly to tell how its acting now? i saw your previous post.
